1991 Chevy Camaro won't run
KATHYBHAM
  • 1991 CHEVROLET CAMARO
  • 6 CYL
  • 113,000 MILES
Starts up and idols will not take the gas. When you give it the gas it quits running. Replaced the fuel pump.
Wednesday, September 29th, 2010 AT 8:13 PM
HMAC300
  • 48,601 POSTS
First scan your engine for codes. Cross A&B on the aldl and count the flashes with the key turned on. Then check to see if you rmap sensor is any good. Also check your fuel pressure, it should be 40p. Si. Minimum HOpefully you changed the fuel filter when you replaced the pump. Also check to see if the tps isn't stuck.
Friday, October 1st, 2010 AT 7:50 PM
