1991 Chevy Camaro convert a 350 to a tpi
1991 CHEVROLET CAMARO
999,999 MILES • V8 • 2WD • AUTOMATIC
CLAPPER105701
i want to buy a 1991 rs camaro i think it had a 305 tpi in it but im not sure ill have to run the numbers. but i was wondering if it did have the 305 tpi could i take an old 350 block and build it to where it will run off of the tpi instead of carb. if so what would i have to do? and would the wiring harness for the 305 tpi be the same as 350 tpi?
Apr 24, 2008 at 8:03 AM
BLACKOP555
  • 10,386 POSTS
you can try to hook up a tpi instead of a carb but you will need a bit of modifications that you will not be capable of yourself.
the wiring harness will also be different from a 305 and a 350, not much but different if they are both tpi.
Apr 24, 2008 at 10:14 AM
