1987 Chevy Camaro Wont start sometimes
GAVGAGE24
  • 1987 CHEVROLET CAMARO
Electrical problem
1987 Chevy Camaro V8 Manual 101, 20 miles
When I start my camaro it starts just fine. When I shut it off and try to start it back up a short time later it wont start. Its like it wont start when its heated up. Any ideas?
Thursday, March 4th, 2010 AT 5:00 PM
Next time it does that don't wait do below to determine if its fuel or spark problem
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Thursday, March 4th, 2010 AT 6:14 PM
