1987 Chevy Camaro Running Hot
3,000 MILES • V8 • 2WD • AUTOMATIC
WILLIAMSUHAR
I have a 1987 Camaro with a recently rebuilt 305ho chevy small block and the temperature gauge reads 210 degrees when it warms up. Is this a normal running temperature or is it overheating? Also when I turn it off the gauge goes way up(like 235) although I know its not getting hotter while it's off, and the heat is always on. Any advise?
Jul 3, 2009 at 4:06 AM
  • 110,248 POSTS
Actually 210 isn't too bad. The t-stat is designed to fully open at 195 unless it was replaced with a hotter one. You could try replacing it and flushing the cooling system to see if that helps.
Jul 3, 2009 at 10:27 AM
