1987 Chevy Camaro I want to convert from TPI fuel injection
1987 CHEVROLET CAMARO
115,025 MILES • V8 • 2WD • AUTOMATIC
AHSDRUMMER920
I would like to convert my Chevy Camaro's Fuel injection into carb. Its A 350 stock motor. How would i go about doing this and what are the things im going to half to buy and do to do this. Am i going to have any porblems down the road? Thank you
Feb 20, 2008 at 8:49 AM
MASTERTECHTIM
  • 4,750 POSTS
you will have to change the flywheel and install a distrubutor from a hei system and wire it to ignition voltage. the starter will also be different. other than that it is pretty much straight forward. i have actually done this and these are the only differences. you can run the fuel pump off the engine and leave the electric pump in the tank but disconnect the electrical plug or cut the gray wire at the sending unit.
Feb 20, 2008 at 9:30 AM
JEFF79
I am actualy doing a swap from a v6 to a carberated v8... you said that I can use the stock tank and just disconect the wires to the pump in the tank??? does this mean that the fuel will just pass through the old pump without it pumping fuel? Thanks for the input...
Aug 24, 2008 at 6:54 PM
