Saturday, July 31st, 2010 AT 10:39 PM
How do I set the distributor timing? There appears to be three marks on the balancer to indicate TDC. How do I know which one to use? I can turn the carnk with a ratchet and align the marks but which one is correct? The distrubutor was pulled out by the owner I need the the correct tdc mark and firing order on a 2.8 cylinder engine were should the timig be after I have align my marks with the tdc and ditrubutor thanks for all your help
