engine stalls at idle
MARK85345
Engine problem
1985 Chevy Camaro V6 Two Wheel Drive Automatic 175000 miles
When my car is sitting out in the cold overnight and I go to start it in the morning it dies when it idles and I have to rev the engine for a couple minutes to start it. Check engine light comes on; seems to occur mostly in cold weather.
Dec 8, 2007 at 10:26 PM
  • 75,988 POSTS
Check the coolant temperature sensor, idle air control valve and throttle position sensor
Dec 8, 2007 at 10:39 PM
  • 55,647 POSTS
I think you should run the codes to see which ones are stored, here is a guide to help.
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
A vacuum leak can cause this issue as well, here is a guide to help you fix it.
https://www.2carpros.com/articles/stall-at-idle
Please go over these guides and get back to us.
Aug 2, 2024 at 3:55 AM
