1984 Chevy Camaro engine will not run unless I keep my foot
BKOAHSWRSTLR
  • 1984 CHEVROLET CAMARO
  • V8
  • 135,000 MILES
I recently decided to replace my valve cover gaskets due to the fact that they were leaking. After replacing the gaskets and reassembling the engine I can not keep the car running unless I constantly rev the engine once I stop revving it the car stalls out. What could be wrong with it?
Monday, September 13th, 2010 AT 7:13 PM
Clean out the idle air control, EGR and PCV valves and test the TPS-make sure all vac lines are connected to its port and not leaking
Monday, September 13th, 2010 AT 7:31 PM
BKOAHSWRSTLR
Thanks for the info I replaced the egr valve gasket and it's running good now
Tuesday, September 14th, 2010 AT 10:44 PM
