1980 Chevy Camaro TH350 Pan tightening sequence
186,000 MILES • V8 • 2WD • AUTOMATIC
WHITE80Z
  • 10 POSTS
Hello
I have a 1980 Camaro Z28 with the TH350 Automatic. I can't seem to get my pan to stop leaking. It didn't start leaking until I put a shift kit in and reinstalled the pan with a new gasket.
I even purchased a new pan (figuring the old one was warped around the bolt holes) and the leak is worse now!
Is there a specific bolt tightening sequence (like with head bolts) that will make the gasket seal correctly?
Also, is there a type of gasket that prevents leaks?
I've been trying to find this info online, but haven't had any luck
thanks for your help!
patrick
Nov 20, 2009 at 7:36 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Did you use any type of sealant on gasket?
Let me know
Thanks for donate
Nov 20, 2009 at 7:50 AM
WHITE80Z
  • 10 POSTS
nope, didn't use any sealant. I heard it could break off into the pan and get stuck in the passages of the tranny...
Thanks
Nov 20, 2009 at 9:44 AM
DOCFIXIT
  • 18,828 POSTS
That's correct Torque pan bolts to 71-89 inch lbs. use front back side side alternating sequence then torque final in a rotating around pan bolts. Is fluid level correct? is filter paper or pick up screen?
Nov 23, 2009 at 1:50 AM
