1979 Z28 Camaro
CLIFTONJONATHAND
  • 1979 CHEVROLET CAMARO
I recently purchased an electric water pump proform GM. I was wondering if anyone knew besides the normal procedure of hooking it up, if anything else is needed to hook up my fan? There's no pulley on this water pump? Do I need to get an electric fan for my radiator or is there anything that I can do?
Tuesday, March 13th, 2007 AT 1:26 PM
CHEVY22
  • 1,375 POSTS
Are you using it on the street, they were made more so for racing they dont flow as much a a factory pump
Jim
Tuesday, March 13th, 2007 AT 1:59 PM
CLIFTONJONATHAND
  • 8 POSTS
Yes it is for street/strip. Flows 35 gpm. Would I have to have electric fan also?
Thanks for the reply
Wednesday, March 14th, 2007 AT 12:52 PM
CHEVY22
  • 1,375 POSTS
Yup I would get a good one check the cfm, you want one that flow big cfm to try and compensate for the water pump
Wednesday, March 14th, 2007 AT 2:22 PM
CLIFTONJONATHAND
  • 8 POSTS
Alright so once i've gone electric pretty much everything needs to be electric except the alternator and power steering and the crank.
The fan that i've got
778-141-647
from www. Jegs. Com
It has a thermostat in it to be controlled by temp which I like and can set it at 180-240
i will set it at 180 all the time.
Thursday, March 15th, 2007 AT 7:54 AM
