1974 Chevy Camaro Engine berings
57,000 MILES • V8 • 2WD • MANUAL
RBLISS
I through a bering. Not sure if it is the main berring.May only be a lifter bering or cam.Does anyone have a estament for repair? Best and worst case senarios.350ci with modifications.[img:704e88abca]http://www.2carpros.com/forum/automotive_pictures/406157_HPIM0181_1.jpg[/img:704e88abca]
Sep 7, 2009 at 6:31 AM
  • 110,248 POSTS
It is hard to say. If it needs main or rod bearings, the crank needs to come out to be cut or replaced. Basically a complete engine tear down. If that is the case, I would est around 3000.00. Can you describe what you hear, when you hear it, and what the oil pressure looks like?
Also, there are no lifter bearings. There are cam bearings.
Sep 7, 2009 at 3:21 PM
RBLISS
pressure is good on ach cylindar.around 170psi. It squeels and makes a knocking sound when above idle. when I checked the oil I foung metal shavings in the filter.
Sep 8, 2009 at 2:05 AM
  • 110,248 POSTS
If the sound is coming from the bottom of the engine, chances are it is a main bearing or rod bearing. The only way to know if to remove the oil pan and use a product called plastigauge. You place it between the bearing, retighten the bearing and then, based on how much it flattens out will tell you where there is too much play.
Sep 8, 2009 at 3:15 AM
