1967 Chevy Camaro Starter Noisy When Hot
125,000 MILES • V8 • 2WD • AUTOMATIC
DELGESU1776
The starter when cold starts fine and without noise. After the car has been driven any length of time at all the starter will spin until it sounds like it hits something solid with a loud clang. If you keep trying to start it it will keep doing the same thing until it sits for 15-30 minutes then starts normal.
I have been told that since I run header without a heat sheild on the starter that could be the culprit.
Besides that I am at a loss.
Jun 14, 2009 at 7:50 AM
  • 110,246 POSTS
The heeaders could be causing th starter to get too hot, so that suggestion may be correct. However, if you hear the starter spin, then kick into the flywheel, it sounds like you have a bad solenoid on the starter. NOTE: The heat could be causing the solenoid not to work properly.
Does it always work fine when cold?
Jul 3, 2009 at 11:59 AM
