1975 Chevy Camaro starter
RTHROOP
  • 1975 CHEVROLET CAMARO
Engine Mechanical problem
1975 Chevy Camaro V8 Two Wheel Drive Automatic
just put in a new starter, used the shims in each and everyway. On the starter sound like it still stays on when I start the engine. What do I do?
Saturday, January 23rd, 2010 AT 5:52 PM
DOCFIXIT
  • 18,828 POSTS
Remove battery cable at starter connect remote switch to batt and solenoid terminal. Engage to move pinion gear out to fly wheel having loosened starter bolts bend up a paper clip adjust with shims until clip can be inserted between pinion and flywheel gear.
Monday, January 25th, 2010 AT 11:05 AM
