Power Brake Booster
ROBERTMCHRISTIAN
I have a 95' S-10 Blazer, mileage 136,000 and when I press the brake pedal I hear a hissing noise and the brakes become really stiff, not to the floor like other forums I have read. I have been told that the brake booster needs to be replaced? Easy enough, but I was wondering if there was any chance it could be the breaker rather than the booster, and if so how would I check? I have no vacuum leaks under the hood that I can tell. Any help would be appreciated! Thanks!
Aug 23, 2007 at 4:01 AM
BOOTDOG
  • 665 POSTS
you have a 1 vacuum hose that runs to the booster, make sure the hose isn't leaking or disconnected. if ok, the replace the booster.
Mar 19, 2021 at 5:05 AM
RAYT333
  • 27 POSTS
Like already stated, you just need to replace the booster. I have had 2 blazers and had to replace the booster in both of them. It is a fairly easy job though.
