1992 Chevy Blazer Stalls in Gear
MUCHCLEAVAGE
My '92 S10 Blazer, 2wd, auto, V6 Vortec engine. My Blazer starting having problems all of the sudden with no warning! It starts up fine, idles smooth until you put it in gear... rev or drive, doesn't matter! Then it stalls and dies! Doesn't want to accelerate. Then once you get it going it seems OK until you come to a stop! I took it to the dealer and they found nothing on the diagnostic. We have changes everything we could think of! Any suggestions!!!!!!
Jul 5, 2007 at 2:15 PM
E40WATER12
  • 522 POSTS
I would get a fuel pressure test done, Has the truck had a full tune up?. fuel filter been replaced?. Also could have a bad fuel regulater as well.
Jul 5, 2007 at 8:38 PM
VALDESS10
I HAVE THE SAME PROBLEM, WHEN IT GETS HOT 5 MINUTES IT STALLS AS SOON AS YOU GET IT IN REVERSE OR DRIVE. HAVE REPLACED FUEL FILTER, PLUGS , NEW WIRE. NEED HELP!!!, ANY SUGESTIONS. CAN NOT EVEN DRIVE IT TO MECHANIC!!! ALSO FEELS LIKE I HAVE NO BRAKES !!!
WHEN COMING TO A STOP.
Oct 12, 2007 at 5:36 AM
Suggested Repair
Have fuel pressure tested and inspect the fuel pressure regulator. Confirm a full tune-up and that the fuel filter has been replaced.
Conversation Summary
A 1992 Chevy S10 Blazer starts and idles fine but stalls when shifted into gear and hesitates until it is moving, then stalls again at stops. The dealer found no diagnostic codes. An expert recommended a fuel pressure test, a full tune-up, fuel filter replacement, and checking for a bad fuel pressure regulator. Another owner reported the same hot stalling after replacing the filter, plugs, and wires, and also noted weak brakes when stopping.
