1999 Chevrolet S-10 Running on 2 Cylinders
LORI SCARBERRY
I have a 1999 S-10 pickup, 4 cylinder, 130,000 mileage. I have had new fuel injectors, tune-up, fuel pump pressure tested, and fuel filter. I am still only hitting on 2 cylinders. What could be the problem?
Feb 19, 2007 at 12:56 AM
CHEVY22
  • 1,375 POSTS
sounds like you may have a coil pack that went bad , a very common problem on the 2.2 , check for spark at the plugs that you say are not firing , if no spark replace both coil packs and the module, some people dont replace both but if one goes bad the other isnt far behind and the module under the coil could have failed , so if no spark replace all three components , if you do have spark check the compression in the cylinders that arent firing
jim
Feb 19, 2007 at 1:51 AM
Suggested Repair
Check spark at the plugs that are not firing. If there is no spark, replace both coil packs and the ignition module. If spark is present, check compression on the cylinders that are not firing.
Conversation Summary
The owner of a 1999 Chevrolet S-10 4-cylinder with 130,000 miles says the engine still runs on only two cylinders after new fuel injectors, a tune-up, a fuel pump pressure test, and a fuel filter. The expert says a failed coil pack is common on the 2.2 and recommends checking spark; if spark is absent, replace both coil packs and the module, and if spark is present, check compression.
