My 94 S-10 Blazer idles real high?
MOLLY JEAN
  • 1994 CHEVROLET BLAZER
I have only had it a year, it has always idled alittle higher than normal. Now it idles so high I am scared to drive it. It doesn't kick down at all. I have had the EGR valve cleaned and replaced, an IAC replaced also. Any advise would be greatly appreciated.
Monday, February 26th, 2007 AT 11:31 AM
LYTN_J
  • 19 POSTS
Check for troublecodes, anything? On a speed density system, a vacuum leak can cause the idle to go high. When I replace an IAC valve, I take the throttlebody off and give all the passages a good cleaning. Make sure the throttle valve is closing. On a cold engine, the CTS might be an issue, I'm not saying replace it.
Tuesday, February 27th, 2007 AT 7:00 AM
