2001 Chevrolet Blazer RPM Surge
RAIDER4180
2001 Blazer, 97K miles, 4.3L, 2 door, 4x4, manual.
When I'm driving, as soon as I push the clutch in to shift gears, the RPM's go up. If I let it go without shifting, it will go up to about 3,000 RPM and stay there for about 5 seconds, and then slowly go back down. It isn't always that high or that long, but this is what it normally does. Once the RPM's go back down, it idles fine, and seems to run fine otherwise. It usually doesn't do this until I have been driving for a while. It also didnt seem to do it as much in the winter as in the summer. It does not leak anything or run hot, and my gas mileage seems normal.
also, i do not know if this is related, but I get a service engine light every now and then. I borrowed a cheap code reader from a friend, and it came up with "0122." I cant seem to find anywhere what that means.
Thanks in advance for any help!
Jun 22, 2007 at 3:04 PM
E40WATER12
  • 522 POSTS
I would find out the troubles thats displayed, with the check engine light on, I think by replacing that sensor it should correct youre problem.
GoodLuck.
Jun 23, 2007 at 10:39 AM
TOYPAR
  • 12 POSTS
I looked the code up for you and it is the Throttle Position Sensor. a 50$ Autozone fix.
Jun 26, 2007 at 2:24 AM
TOYPAR
  • 12 POSTS
Google: DTC P0122
RAIDER4180
thanks guys. is it hard to replace on my own?
Jun 26, 2007 at 4:08 AM
Suggested Repair
Confirm DTC P0122 and replace the throttle position sensor, an inexpensive part that replies say should correct the RPM surge.
Conversation Summary
A 2001 Chevrolet Blazer owner reports that RPMs rise when the clutch is pressed, often to about 3,000, then slowly return to a normal idle. The issue is more common after driving and in warm weather, and an intermittent check engine light shows code P0122. Replies identify the throttle position sensor and recommend replacing it.
