High idle and stalls
139,780 MILES • 4.3L • V6 • 4WD • AUTOMATIC
BLAZERS99
I put in a new fuel regulator new gaskets new crank sensor new pigtail for crank position sensor it ran fine then the regulator went out so I put new one in and gaskets. It idles at 3,000 and if I goes under it shuts off unless I unplug mass air flow sensor then it steadily idles at 3000. would the upper intake gasket be leaking or did I mess something up cleaning the MAF and IAC and TPS?
Apr 15, 2017 at 11:09 AM
  • 55,743 POSTS
It sounds like something got messed up, is ti check engine light on? If not please run the codes anyway to see what part we need to look at.
Recheck the TPS connector to make sure its plugged in all the way,
Best, Ken
Apr 18, 2017 at 4:53 AM
STEVE W.
  • 15,417 POSTS
Vacuum leak would be a start. The gasket for the injector to upper intake and the upper to lower are common issues, if they get moved just a bit they leak.
Then the IAC which is nothing but a computer controlled vacuum leak! Also check the EVAP purge solenoid. The plastic can easily get cracked on them and leak.
Apr 19, 2017 at 2:57 PM
