1995 blazer 112000 miles,4.3 vortec.
my blazer just died and will not start,after checking the fuses,the ecm fuse was blown.everytime i replace it it blows as soon as i turn the key on.i pulled the dist.cap and found that 1 screw had come out of the rotor and fallen inside the dist.i straightened that up and still same results.now its tricky.if i un plug the dist module it still blows the ecm fuse when the key is turned on.if i plug the module in and un plug the computer it doesnt blow.when i plug in computer it blows.is it in computer.with the dist unopluged it still blows ecm when computers plugged in.please help
Aug 30, 2007 at 12:47 PM
