1995 Chevrolet Blazer ECM Fuse Blows
MECHTOM
1995 blazer 112000 miles,4.3 vortec.
my blazer just died and will not start,after checking the fuses,the ecm fuse was blown.everytime i replace it it blows as soon as i turn the key on.i pulled the dist.cap and found that 1 screw had come out of the rotor and fallen inside the dist.i straightened that up and still same results.now its tricky.if i un plug the dist module it still blows the ecm fuse when the key is turned on.if i plug the module in and un plug the computer it doesnt blow.when i plug in computer it blows.is it in computer.with the dist unopluged it still blows ecm when computers plugged in.please help
Aug 30, 2007 at 12:47 PM
  • 75,988 POSTS
This sounds like you have a shorted ignition coil or oxygen sensor please unplug them to see which one blows the fuse.
Sep 1, 2007 at 12:54 AM
LADYMERK
hello, im having the same problem with my 01' blazer. ive blown more than 60 fuses in last month. its gotta be a wiring issue since everything else is replaced. 500$ later and a new starter its still blowing. my mechanic showed me how to change the fuse when it blows so he dont have to come rescue me wherever i broke down. im on here looking for a second opinion because im wasting money and time with my mechanic whos doing process of elimination and is still baffled to whats going on. starter was replaced again and still blowing fuses. harness is okay and runs great when its started. if the fuse is changed and i dont drive a little (just turn blazer off and try to start again) it blows repeatedly. if fuse is changed and i drive a block, shut it off...it will start back up. but 2-4 days later fuses will blow again. Then I found this post and discovered a shorted ignition coil causing the problem, all fixed, I love this site.
Apr 19, 2012 at 9:27 AM
Suggested Repair
Unplug the ignition coil and oxygen sensor one at a time with the key on to see which circuit blows the ECM fuse, then replace the shorted part.
Conversation Summary
A 1995 Chevrolet Blazer with a 4.3 Vortec dies and blows the ECM fuse as soon as the key is turned on, even after a loose distributor rotor screw is corrected. The fuse still blows with the distributor module unplugged when the computer is connected, but not when the computer is unplugged. An expert advises unplugging the ignition coil and oxygen sensor to find which one is shorted. A later owner of a 2001 Blazer with repeated fuse failures reports that a shorted ignition coil was the cause and replacing it fixed the problem.
