1999 Chevrolet Blazer No Floor Heat
GLEN133
1999 Chevrolet Blazer. 4.3 Engine 85270 miles: My Heater will not blow onto floor. it will switch to defrost or Panel {face} only. you can switch it to floor but it comes out up top. any suggestions. :(
Feb 6, 2007 at 7:52 AM
SERVICE WRITER
  • 9,123 POSTS
Sounds like it may have a broken control lever that operates the vent flap (valve) to allow air to move. It's in the heater box, in the dash.
Feb 6, 2007 at 10:00 AM
FFAS23
  • 25 POSTS
[quote:71bbec707d="GLEN133"]1999 Chevrolet Blazer. 4.3 Engine 85270 miles: My Heater will not blow onto floor. it will switch to defrost or Panel {face} only. you can switch it to floor but it comes out up top. any suggestions. :([/quote:71bbec707d]
Get a flashlight and take a look under the dash. It may just be a vacuum hose that disconnected that opens that duct.
Feb 7, 2007 at 12:20 AM
Suggested Repair
Inspect the heater box under the dash for a broken control lever that moves the vent flap, and check for a disconnected vacuum hose that opens the floor duct.
Conversation Summary
A 1999 Chevrolet Blazer heater will not direct air to the floor; selecting floor still sends air to the upper vents, while defrost and panel modes work. An expert suggested a broken control lever for the vent flap inside the heater box. Another reply suggested checking under the dash for a disconnected vacuum hose that opens the floor duct.
