2001 Chevrolet Blazer No Heat
Hope this helps Backyardmechanic :)
Suggested Repair
After the thermostat replacement, fill and bleed the cooling system completely. Run the engine to full operating temperature with the heat on and recheck the coolant level, topping it off if trapped air caused it to drop. If there is still no heat, disconnect both heater hoses and flush the heater core with a garden hose until the water flows freely and no debris remains.
Conversation Summary
The owner of a 2001 Chevrolet Blazer said the heater was weak, then had no heat at all after replacing the thermostat, and asked whether the heater core was failing. The expert said a failed heater core was unlikely and advised confirming the cooling system was full after air bled out at operating temperature with the heat on. If that did not restore heat, the expert recommended flushing the heater core through both heater hoses until debris stopped coming out. The owner later reported the heater was working fine without flushing.
