1993 Chevy Pickup Heater Blows Cold
1993 CHEVROLET
DODGER#1
  • 9 POSTS
1993 Chevy Pickup Chyene 1500 V6: I'm having a problem with my heater. The problem with it is that when i turn it on it blows cold air only through all the vents. Put when i put my thermostat to hot air it wont throw the hot air in.There is no vaccum hoses broken nor anything leaking. Can u guys help me out? And Thank u.
Dec 13, 2006 at 12:30 PM
BACKYARDMECHANIC
  • 337 POSTS
Sounds like the heater core is clogged. How is the car running reguarding the temperature. If its running cool then the thermostat is either struck open or has been removed .Are you the original owner? BYM
Dec 15, 2006 at 5:22 AM
DODGER#1
  • 9 POSTS
The tempature is running fine.nor any thermostat has been removed. It just stop heating when i turn on the heater. It turns on but just cold air comes out. And yes im the original owner.
Dec 15, 2006 at 4:48 PM
BACKYARDMECHANIC
  • 337 POSTS
Check that the heater control valve (if equipped) is opening if this is operating correctly than you need to flush the heater core. Do this by removing both hoses from the heater core and using a garden hose. Continue to flush until you have a good flow.
Dec 15, 2006 at 10:56 PM
Suggested Repair
Confirm the heater control valve, if equipped, is opening. If it operates correctly, disconnect both heater-core hoses and flush the core with a garden hose until flow is strong.
Conversation Summary
The owner of a 1993 Chevy Cheyenne 1500 V6 pickup reports that the heater runs but blows only cold air from all vents, with no broken vacuum hoses or leaks. Engine temperature is normal and the thermostat has not been removed. The expert first suspected a clogged heater core or a thermostat stuck open or missing, then advised checking that the heater control valve opens and flushing the heater core with a garden hose until flow is good.
