1995 Chevy Blazer No-Start Fuel Issue
I bought a used 1995 Chevy Blazer S-10. Approx. 172,000 miles, V6. It started before I bought it. Now it won't start. My mechanic had narrowed it down to the computer. He ordered a brand new one. When it arrived he found that the Chevy dealer has to install it because it comes blank and they have to program it. So he had it towed to the local Chevy dealer who installed the new computer. The computer which is brand new and has never been on a vehicle which has fired, including the Blazer it was just installed on, is now running codes, one of which is saying that the ignition module is bad. Is this true that a computer which is brand new can have codes on a vehicle that it hasn't been fired on? Thank you for any help.
Feb 9, 2007 at 8:41 AM
He didn't narrow down nothing-he misdiagnosed it. Now you're stuck with a new PCM. Basic stuffs would have caught the No spark and signal to the PCM with a scantool.
Get rid off the partchanger-donate and we will find your problem-everybody making money here except us.
Feb 9, 2007 at 9:29 AM
I guess I should have elaborated a bit more. There Is spark. And when you spray stuff in carb.-engine fires but as soon as you take it away the engine stops. It has new fuel pump assembly and filter. Mechanic said there is fuel right up to the plenum and the injector is OK. My only question is if the computer can show codes on a vehicle that has never been started with that computer before. Thank you.
Also is there a mailing address to send a donation? I do not have credit card and have never used PayPal. Thank you.
Feb 12, 2007 at 12:10 AM
Get a partner crank the engine over whlile listening to the injectors-is it clicking?
Have the fuel pressure check-its a critical thing must be in specs for EFI system. Could be the pressure regulator not maintaining the pressure. You have a fuel problem.
Feb 12, 2007 at 6:00 AM
Suggested Repair
Have a helper crank the engine while listening for injector clicking, and check fuel pressure against specification. A regulator that will not hold pressure is a likely cause. A new PCM can report codes from current circuit conditions even if the vehicle has not run with it.
Conversation Summary
A 1995 Chevrolet Blazer with a V6 will not stay running. It has spark and fires briefly when starting fluid is sprayed in, then dies. The fuel pump and filter are new, and fuel reaches the plenum. After a new PCM was installed and programmed, it set codes including a bad ignition module. The expert said the PCM was likely misdiagnosed and advised checking injector clicking during cranking and verifying fuel pressure, noting the regulator may not be maintaining pressure.
