1989 Chevrolet Blazer Engine Swap
DIGGIDY
I have an 1989 S-10 Blazer with a 4.3, its a 4x4, automatic with 109k miles. It has a bad engine. I found a 4.3 out of a 85 Monte Carlo. What problems will I face tring to put this engine in my truck? Thanks
Jun 23, 2007 at 8:31 AM
E40WATER12
  • 522 POSTS
I am sure it will work, With a bit of fab work, Is youre
1989 S-10 Blazer with a 4.3 fuel injected?, How about the 85 monte carlo, Motor fuel injected or carbed?. Well you could use the block from the monte carlo, swap over the intake off youre Blazer, Then u wont have to swap over the wiring harnesses, I would just make sure get things are complete from the monte carlo motor so then u dont have to go to the wreckers to grab parts.
GoodLuck.
Jun 23, 2007 at 10:37 AM
DIGGIDY
Thanks for the reply. Im gonna try to do this swap with my brother. Im thinking I should keep the intake, fuel injection, wire harness, and oil pan from the Blazer and everything else should be fine. What about the motor mounts?
Jun 23, 2007 at 12:28 PM
E40WATER12
  • 522 POSTS
I would just keep both motor mount from the monte carlo as well, If u need them then u got them.
Jun 25, 2007 at 7:55 PM
Suggested Repair
The Monte Carlo 4.3 block may fit with some fabrication. Confirm whether each engine is fuel injected or carbureted, then reuse the Blazer intake so its fuel injection and wiring harness can stay. Keep the donor engine complete and retain its motor mounts in case they are needed.
Conversation Summary
The owner of a 1989 Chevrolet S-10 Blazer 4.3 4x4 automatic wants to install a 4.3 from a 1985 Monte Carlo and asks about compatibility and motor mounts. The expert says the swap should work with fabrication, recommends using the Monte Carlo block with the Blazer intake to avoid a harness swap, and suggests keeping the donor mounts available.
