Blazer Distributor Rotor Keeps Going Bad
ABRANCH352
I have a 1999 Chevy Blazer 2wd 4.3L automatic with 155K miles. It starts out running rough first thing in the am. After a few more weeks it get worse and acts up anytime of the day (worse in am). I can change the rotor and it will run perfect for 1 to 2 months. I have tried 3 different brands of rotors including OEM Chevrolet with no success. This problem started about 125k miles. I have had it tuned up, including distributor cap, wires and plugs. Any ideas? Thanks.
Oct 10, 2007 at 4:27 AM
BMRFIXIT
  • 19,053 POSTS
[quote:b42e060026="abranch352"]I have a 1999 Chevy Blazer 2wd 4.3L automatic with 155K miles. It starts out running rough first thing in the am. After a few more weeks it get worse and acts up anytime of the day (worse in am). I can change the rotor and it will run perfect for 1 to 2 months. I have tried 3 different brands of rotors including OEM Chevrolet with no success. This problem started about 125k miles. I have had it tuned up, including distributor cap, wires and plugs. Any ideas? Thanks.[/quote:b42e060026]
check the dist if ok
try a new cap and rotor
good luck
Oct 10, 2007 at 2:45 PM
ABRANCH352
Thanks for the reply.
I think I worded my question poorly. What I should have asked is what is causing the rotor to keep going bad? I have changed it 3 times with different brands and they all keep going bad. Thanks
Oct 11, 2007 at 1:05 AM
SERVICE WRITER
  • 9,123 POSTS
There is a vent on the distributer that gets plugged up and may be casuing the problem.
Oct 11, 2007 at 11:12 PM
BAT KID
  • 48 POSTS
where is the vent located on the distributor because my cap and rotor keep corroding
Apr 12, 2011 at 8:05 AM
