1995 Chevrolet Blazer Brake Booster Hiss
ROBERTMCHRISTIAN
I have a 95' S-10 Blazer, mileage 136,000 and when I press the brake pedal I hear a hissing noise and the brakes become really stiff, not to the floor like other forums I have read. I have been told that the brake booster needs to be replaced? Easy enough, but I was wondering if there was any chance it could be the breaker rather than the booster, and if so how would I check? I have no vacuum leaks under the hood that I can tell. Any help would be appreciated! Thanks!
Aug 23, 2007 at 4:01 AM
BOOTDOG
  • 665 POSTS
you have a 1 vacuum hose that runs to the booster, make sure the hose isn't leaking or disconnected. if ok, the replace the booster.
Mar 19, 2021 at 5:05 AM
RAYT333
  • 27 POSTS
Like already stated, you just need to replace the booster. I have had 2 blazers and had to replace the booster in both of them. It is a fairly easy job though.
Suggested Repair
Check the vacuum hose to the brake booster for leaks or disconnection. If the hose is intact, replace the brake booster.
Conversation Summary
The owner of a 1995 Chevrolet S-10 Blazer reports a hissing noise and a stiff brake pedal when braking, and asks whether the booster or another part is at fault. Experts advise checking the booster vacuum hose and replacing the booster if the hose is sound.
