1999 Chevy Blazer Rotor Keeps Failing
ABRANCH352
I have a 1999 Chevy Blazer 2wd 4.3L automatic with 155K miles. It starts out running rough first thing in the am. After a few more weeks it get worse and acts up anytime of the day (worse in am). I can change the rotor and it will run perfect for 1 to 2 months. I have tried 3 different brands of rotors including OEM Chevrolet with no success. This problem started about 125k miles. I have had it tuned up, including distributor cap, wires and plugs. Any ideas? Thanks.
Oct 10, 2007 at 4:27 AM
BMRFIXIT
  • 19,053 POSTS
[quote:b42e060026="abranch352"]I have a 1999 Chevy Blazer 2wd 4.3L automatic with 155K miles. It starts out running rough first thing in the am. After a few more weeks it get worse and acts up anytime of the day (worse in am). I can change the rotor and it will run perfect for 1 to 2 months. I have tried 3 different brands of rotors including OEM Chevrolet with no success. This problem started about 125k miles. I have had it tuned up, including distributor cap, wires and plugs. Any ideas? Thanks.[/quote:b42e060026]
check the dist if ok
try a new cap and rotor
good luck
Oct 10, 2007 at 2:45 PM
ABRANCH352
Thanks for the reply.
I think I worded my question poorly. What I should have asked is what is causing the rotor to keep going bad? I have changed it 3 times with different brands and they all keep going bad. Thanks
Oct 11, 2007 at 1:05 AM
SERVICE WRITER
  • 9,123 POSTS
There is a vent on the distributer that gets plugged up and may be casuing the problem.
Oct 11, 2007 at 11:12 PM
BAT KID
  • 48 POSTS
where is the vent located on the distributor because my cap and rotor keep corroding
Apr 12, 2011 at 8:05 AM
Suggested Repair
Inspect the distributor and clear its vent, which can plug and cause moisture or corrosion that repeatedly ruins the rotor. Replace the distributor cap and rotor together after checking the distributor.
Conversation Summary
The owner of a 1999 Chevy Blazer 4.3L reports rough running, worse in the morning, that returns every one to two months as the distributor rotor fails. Multiple rotor brands, including OEM, fail the same way despite a tune-up of the cap, wires, and plugs. Experts suggest checking the distributor, replacing the cap and rotor together, and clearing a distributor vent that may be plugged and causing the repeated failure.
