HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Blazer
Ignition
Distributor
Rotor
2000 Chevy Blazer
AMERICANPRIDE_02
MEMBER
2000 CHEVROLET BLAZER
6 CYL
4WD
AUTOMATIC
127,000 MILES
My blazer is miss fireing what is the problem I changed plugs, wires, dist cap, and dist rotor
Sunday, September 12th, 2010 AT 5:28 PM
MECHANIC
Engine running rough or misfiring can be cause by the following:
1. Defective spark plug
2. Inadequate spark/coil, defective spark plug wire.
3. Lack of compression
4. False air leakage.
5. Faulty fuel injectors.
6. Insufficient fuel pressure.
7. Contaminated fuel.
8. EGR valve that is leaking.
9. Oxygen sensors.
10. Throttle position sensor.
11. Idle air control valve.
SPONSORED LINKS
Sunday, September 12th, 2010 AT 7:51 PM
Please
login
or
register
to post a reply.
Related Ignition Distributor Rotor Content
Blazer Distributor Rotor Keeps Going Bad
I Have A 1999 Chevy Blazer 2wd 4.3l Automatic With 155k Miles. It Starts Out Running Rough First Thing In The Am. After A Few More Weeks It...
Asked by
abranch352
CHEVROLET BLAZER
Distributor Rotor Removal
Chevrolet, S10 Blazer, 1993, 166,000 Mi, 4.3l V6. Recently My Blazer Was Running Rough And I Found The Distributor Cap Was Cracked. I...
Asked by
Garys75431
CHEVROLET BLAZER
Exact Positioning Of The Gm 4.3 Distributor Rotor Tip
I Would Like To Know The Exact Positioning Of The Gm 4.3 Distributor Rotor Tip. The Distributor Was Removed Without Any Timing Marks. This...
Asked by
probowhunter1959
1 ANSWER
7 IMAGES
1995
CHEVROLET BLAZER
1997 Chevy Blazer Help! Distributor Problems.
Electrical Problem 1997 Chevy Blazer 6 Cyl Two Wheel Drive Automatic I Have Replaced The Distributor On My 97 Blazer. Before Placing...
Asked by
baldarmyguy78
1997
CHEVROLET BLAZER
Distributor Cap ?
The Distributor Cap On My 1999 Blazer Reads 3, 1, 5 On The Driver's Side And 2, 4, 6 On The Passenger Side. Do These Numbers Correspond...
Asked by
bugsbunny16374
1999
CHEVROLET BLAZER
VIEW MORE
SPONSORED LINKS
Misfire
Topdon OBD2 Scanner Review - This thing rocks
Spark Plug Replacement Honda
Online car repair manuals
