2000 Chevrolet Blazer A/C Drain Location
AARNDT
Where exactly is the a/c water condensation drain on a 2000 Blazer?
Thanks.
Nov 10, 2007 at 8:12 AM
CHEVY22
  • 1,375 POSTS
its on the passenger side under the evap core housing against the firewall , if you get on the ground behind the right front wheel you can see it there
Nov 10, 2007 at 1:23 PM
Suggested Repair
Locate the A/C condensation drain on the passenger side under the evaporator core housing against the firewall. It can be seen from the ground behind the right front wheel.
Conversation Summary
The owner asked where the A/C condensation drain is on a 2000 Chevrolet Blazer. The expert said it is on the passenger side under the evaporator core housing against the firewall and can be seen from the ground behind the right front wheel.
