1997 Chevy Blazer No Air from Vents
65CHEVYTRUCK
I have a '97 Chevy Blazer, 167k miles, auto trans, 4.3L engine, 4wd. Just changed the alternator, now no air blows out of the vents, seems to be stuck in defrost/floor mode. Last time this happened, it was the vacuum accumulator. Chiltons doesn't show how to check if that's the problem. Any advice?
Aug 28, 2007 at 5:48 AM
CLY
  • 308 POSTS
There is vacumm line that runs right behind the alternator. Follow that line to see if it came off. I think that the vacumm canister is probably disconnected. If you dont see that line then look for a vacumm ine coming from the firewall on the passanger side and follow it to see where it goes...
Cly
Aug 28, 2007 at 9:36 AM
Suggested Repair
Inspect the vacuum line behind the alternator and reconnect it if it came off. Also follow the vacuum line from the passenger-side firewall to the vacuum canister and reconnect any disconnected line.
Conversation Summary
The owner of a 1997 Chevy Blazer reports no air from the vents and the HVAC stuck in defrost/floor after an alternator replacement, and suspects the vacuum accumulator. The expert advises checking the vacuum line behind the alternator and tracing the passenger-side firewall vacuum line to see whether the vacuum canister is disconnected.
