1999 Chevy Blazer Signals Flash Off
EZEGLEN
I have a 1999 Chevy Blazer, 4.3, 4door, 4x4 with 106000 miles. My turn signal flasher unit continues to flash when my signals are not on. Sometimes coming on when I hit a bump in the road. I changed the flasher unit behind the glove box and it seemed to help for a while but now it is doing the same thing. I found out today that my 4way flashers do not work. Sometimes when I wiggle the switch on the column I can get my flasher unit to 'click' but no lights come on. My turn signals seem to work fine, most of the time the clicking does stop when I manually stop it, or the cancelling cam stops it. But I can still here it when I hit a bump and my emergency flashers still don't work.
I checked on recalls, it looks like the 2000 and early 2001 models were recalled for this issue.
Aug 16, 2007 at 5:41 AM
POET042005
  • 134 POSTS
You may have a bad Hazard switch. Take the car to a autozone or murrays and have the car scanned for codes, one thing they autozone will only do it if the check engine lite is on. If the lite is not on call murrays or which ever local automotive store you have other then autozone to see if they will do it without the check engine light on.
Keep me posted
Richard
Aug 17, 2007 at 1:48 PM
Suggested Repair
Suspect a faulty hazard switch. Have the vehicle scanned for diagnostic codes at an auto parts store that can scan even if the check engine light is off.
Conversation Summary
The owner of a 1999 Chevrolet Blazer reports the turn-signal flasher keeps clicking when the signals are off, sometimes after hitting a bump. Replacing the flasher behind the glove box helped only briefly. The hazard flashers do not work, and wiggling the column switch can make the flasher click without lighting the lamps, while the turn signals usually cancel normally. The expert suggests a bad hazard switch and recommends a code scan.
