96 Blazer Fuel Pump
RANDAL1
I have a 96 Blazer with 150,000 miles. Two tears ago I replaced the fuel pump. Now when I try to start it I can't hear the pump. I checked the fuse, relays, tried the test wire. Now I'm removing the pump. The connectors at the pump are of an odd configuration and the manual states that I need a special tool. (great) What is the tool and how do I use it?
Thanks
Randal
Sep 25, 2007 at 11:26 AM
FISHERMAN
  • 937 POSTS
Hi!
special tool?
for what?
to crimp the wires on the quick disconnect terminals?
Sep 26, 2007 at 5:35 AM
RAYT333
  • 27 POSTS
maybe the manual states you need a special tool but I wouldn't know what for. Many time a manual calls for a special tool but in many cases a regular tool will work just fine.
Nov 14, 2007 at 2:19 PM
