1993 Chevrolet Blazer No Heat or A/C
DQROKS1
on my heat a/c control which wire would be the hot wire thats tells the blower to turn on and also the a/c compressor i have wiring issues but this would help to know... or is there a relay between the control panel and blower that would tell it to turn on i have replaced the control box its self and no heat/a/c just want to force it on
Oct 23, 2007 at 8:40 AM
2CARPRO JACK
  • 11,533 POSTS
Did you check for power at the fan speed resistor? Should be mounted on the HVAC plenum right near the blower motor
Oct 23, 2007 at 8:46 AM
Suggested Repair
Check for power at the fan speed resistor, which should be mounted on the HVAC plenum near the blower motor.
Conversation Summary
The owner of a 1993 Chevrolet full-size Blazer has no heat or A/C after replacing the control box and wants to identify the hot wire that turns on the blower and A/C compressor, or any relay between the panel and blower. The expert advises checking for power at the fan speed resistor on the HVAC plenum near the blower motor.
