1986 Chevrolet Blazer Heater Resistor Fails
TBJ
I have an 86 full size Blazer 140,000 miles with a 350 that I have to keep changeing the resistor for the heater. after about a month when you turn it on it only works on high after you tap on the heater solinoid. After replacing the resistor it works fine
Feb 16, 2007 at 4:39 AM
CHEVY22
  • 1,375 POSTS
hi
i would check the wiring to the resistor, fan and switch for shorts , there is a problem there somewhere causing the resistor to fail
jim
Feb 16, 2007 at 4:36 PM
CHEVY22
  • 1,375 POSTS
could be but the best thing to do is check resistance on both this will tell you where you stand ,
Feb 22, 2007 at 9:33 PM
Suggested Repair
Check the wiring to the heater resistor, blower fan, and fan switch for shorts or other faults that are causing the resistor to fail repeatedly, and measure resistance in those circuits to locate the problem.
Conversation Summary
The owner of a 1986 full-size Chevrolet Blazer with a 350 says the heater blower resistor must be replaced about every month. After it fails, the fan works only on high until the heater solenoid is tapped. An expert advised checking the wiring to the resistor, fan, and switch for shorts and measuring resistance to find what is causing the resistor to fail.
