Thermostat?
JDONA11196
  • 2000 CHEVROLET BLAZER
  • 6 CYL
  • 104,000 MILES
Temperature gauge is running hot. Have plenty of coolant.
Believe problem is the termostat.
How much should I expect for repair, if so?
Thanks
Friday, September 11th, 2020 AT 3:27 PM (Merged)
BUDDYCRAIGG
  • 2,262 POSTS
You're going to do the job yourself?
It's pretty easy.
Thermostat, gasket, and antifreeze should be about 20 25 buck
KINS508
  • 6 CYL
  • 4WD
  • 114,000 MILES
On my 2000 blazer for the last 2 years I have had to have a coolent flush in order for my heat to be as warm as it should. Normal engien temp is showing around 160 deg. And I can't find any leaks. Is there a electronic damper or something else that might be getting clogged to restrict flow. Tired of having it flushed need to get to the root of the problem instead of putting a bandaid on it. Would a 180 deg thermostat help?
Friday, September 11th, 2020 AT 3:28 PM (Merged)
IMPALASS
  • 3,112 POSTS
Hello
Several things may be the problem. If it has only been the last couple of years then obviously something changed.
Things to check for insufficient heating are, a leak in the cooling system, a low coolant level, a loose or worn drive belt, a leaking or kinked heater hose, a cracked or missing radiator cap seal, a stuck thermostat.
My suggestion is your vehicle calls for a 180 degree thermostat. Your vehicle states the thermostat should begin to open about 188 degrees and be fully open at 206 degrees. You may have a thermostat that is stuck open therefore never allowing the vehicle to properly warm up.
I would inspect the heater hoses really good. See if they are hot. If one is and one isn't then your heater core is plugged.
I would change my thermostat to the 180 degree, you can even go to a 195 degree.
I would also replace my radiator cap.
Your vehicle does have a Heater Core Temperature Sensor Switch but I can not find any information on it... It's location or what it does.
Hope this helps.
SWILLIAMS
  • 597 POSTS
2000 Blazer with a 4.3 should have a 195 degree thermostat. The 4.3 from 1994 up all use a 195. As do 95% of the current vehicles on the road. The 160 is coasting you gas mileage as well as heat. At 160 the computer thinks the engine is still cold and feeds more fuel to the engine.
JW930
  • 6 CYL
  • 100,800 MILES
Hello I have a 2000 Chev Blazer V6. The past few days while driving I have noticed the temp goes to 200 and then goes back down. What could be wrong
Try replacing the thermostat and also test the coolant temperature sensor-
WRENCHTECH
  • 20,761 POSTS
It shouldn't be bouncing around but 200 is not overheating. It may have some air pockets in the system too from a slow leak.
REDDRAGONS
  • 6 CYL
  • 120,000 MILES
The temperature on my Blazer will spike (into the red on the gauge) after about 5 minutes of driving and then gradually drop to normal temperature. When driving in town the temperature quickly climbs when stopped at a light. What is causing this and how do I fix it?
I think my radiator cap is stuck. It turns 1/4 of a turn (which I assume is the correct range) but I can't get it to come up.
DOCFIXIT
  • 18,828 POSTS
Maybe thermostat sticking would be good to replace and flush and fill. Also check fan clutch when vehicle at op temp fan should with resistence and NOT have any wobble. If either replace. As for cap need to apply downward pressure while turning to get past safety lock.
BRIANWBF
  • 6 CYL
  • 4WD
  • 80,000 MILES
Where is thermostat located so that I can replace. Engine never warms above 140 degrees and it is cold up here.
BLACKOP555
  • 10,371 POSTS
Base of the upper radiator hose under what it connects to is the housing, that is where the thermostat is.
