2002 Chevy Blazer car won't start
BRATHOUS
  • 2002 CHEVROLET BLAZER
  • 4 CYL
  • 82,000 MILES
My 2002 Blazer will not start when outside temperature is cold. During warm weather, it will start. If weather is in between, you can usually coax it to start. I have replaced fuel pump, fuel filter, relay, battery. It did not do this last winter - just started a couple of weeks ago. Towed to dealer who could not find anything wrong.
Wednesday, January 16th, 2008 AT 11:47 AM
MASTERTECHTIM
  • 4,750 POSTS
Ive seen this problem a number of times. Unfortunately it usually turns out to be the fuel pump and or the connector at the fuel pump. I strongly recommend using the factory pump in these vehicles. One way to tell if this is your problem, when vehicle wont start, spray starter fluid into intake. This usually gives it enough fuel to start and stay running. I have walked several people through this scenerio with recently replaced fuel pumps and it has always come back to the fuel pump. I hope this helps. Feedback greatly appreciated.
Friday, January 29th, 2021 AT 11:25 AM
