2001 Chevy Blazer lights malfunctioning
2001 CHEVROLET BLAZER
92,000 MILES • 6 CYL • 4WD • AUTOMATIC
STARTECH47
Both filaments light in the 4 each 3057 bulbs when the key is turned on.
When you use the left turn signal the flasher clicks normally and the upper LED brake bar flashes. The left front yellow lights (front and side ) flash alternately.
When you use the right turn signal the flasher clicks rapidly and the upper LED brake bar flashes. The right front yellow lights (front and side ) flash alternately.
The filaments in the bulbs and the sockets look OK. Disconnected and reconnected the battery with no change. Perhaps a ground or turn signal switch?
Checked the 4 way flashers. They operate normally.
Dec 30, 2007 at 8:06 AM
DENNYP
  • 1,824 POSTS
Most likely has a bad turn signal switch.
Dec 31, 2007 at 10:03 AM
