REMOVAL PROCEDURE
TOOL REQUIRED
J 34730-1A Fuel Pressure Gauge
IMPORTANT: Inspect the fuel tank internally and clean the fuel tank if you find a restricted fuel filter. Refer to Fuel System Cleaning.
CAUTION: Refer to Battery Disconnect Caution in Service Precautions.
Disconnect the negative battery cable.
Relieve the fuel system pressure. Refer to Fuel Pressure Relief Procedure.
Clean all the fuel filter connections and the surrounding areas before disconnecting the fuel pipes in order to avoid possible contamination of the fuel system.
Disconnect the quick connect fitting (3) from the fuel filter outlet.
Disconnect the threaded fitting from the fuel filter inlet.
Remove the fuel filter bracket bolt.
Disconnect the fuel pipes from the fuel filter bracket.
Remove the fuel filter from the bracket.
Inspect the fuel O-ring for cuts, nicks, swelling or distortion. Replace the O-ring if necessary.
Thursday, March 7th, 2019 AT 12:33 PM
(Merged)
