fuel filter on chevy blazer
BRUNNER369
My name is aaron and I have a 94 chevy s-10 blazer with an in line fuel filter just under the back driverside door up aginst the frame. I have no idea how to remove the old filter. The bolts are rusted bad so I sprayed them with PB blast several times. Could someone let me know the easyest way to get that filter off. I have tryed for two days now and it will not budge.
Thanks
Aaron Brunner
Jul 22, 2006 at 1:15 AM
PAULB
  • 16 POSTS
I have a 1993 s-10 4 door blazer with the same type filter.Mine was to the point where the bolts wouldn't turn to remove it also.I went to the auto parts store and bought a filter that has the nipple on both ends for a hose to slide on.I used a metal line cutter and cut off both ends of the old filters line,used rubber fuel line hose and clamps and installed the new filter.This way in the future all I have to do is loosen the clamps to change the filter.Hope this helps.
Aug 8, 2006 at 2:55 AM
