2000 Chevy Blazer my battery metter will not go past 14volt
XNOOKX
MEMBER
2000 CHEVROLET BLAZER
6 CYL
4WD
AUTOMATIC
132,000 MILES
I was wandering is this normal cause I recently put a new battery in it and my battery meter still wont go past 14volts
Sunday, December 28th, 2008 AT 1:22 PM
MECHANIC
HI there,
This should not be a problem, the alternator will charge the battery as required and maintain the correct input voltage via the voltage regulator, any more than 14V would be an over charge state and this would boil the battery, if you are concerned get the alternator charge rate checked, but I am sure that all is well and you have no problem.
