2000 Chevy Blazer ball joint
180,000 MILES • 6 CYL • 4WD • AUTOMATIC
DUNLAP25
my car started to pull very badly to the right this went on for 2 days then pulled into my drive and the tire had a popping sound come from around that area of the front end. got out and the driver tire was leaning in on top side. took the tire off and the ball and upper a arm were seperated.
Oct 28, 2010 at 4:28 AM
WRENCHTECH
  • 20,758 POSTS
OK, what's your question?
Oct 28, 2010 at 4:33 AM
DUNLAP25
Oh sorry. Would this have been the cause of my car pulling the way it was? I can see that the lower was replaced so can I just replace the ball joint and not the control arm? And is it easy to do? Thanks
Oct 28, 2010 at 4:45 AM
WRENCHTECH
  • 20,758 POSTS
The ball joint came apart You have to replace it in whatever way the replacement part is sold. If it is only sold with a control arm, then that's what you have to change. This is all assuming no other damage was done when it came apart.
If the joint is sold separately, it can be replaced alone. Just be prepared that I believe the original is riveted in and those rivets will have to be cut or drilled out to get the old one out.
Oct 28, 2010 at 4:52 AM
