2000 Chevy Blazer 2000 Blazer will not prime at times
J-BISH35
  • 2000 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 175,000 MILES
I have a 2000 Blazer which will not prime at times. After you use ether or a little fuel poured in the intake it runs fine. It will usually start back up immediately, but if you wait a while it will not prime again. Sometimes youn can hear the pump prime when the key is in the on position and sometimes you cannot hear it. I've put two new fuel pumps in it and has made no diference. You can hear the relay working also.
Thursday, October 15th, 2009 AT 2:14 PM
Inspect and test the fuel pump relay and the fuel pump/oil pressure sending unit
Thursday, October 15th, 2009 AT 3:21 PM
J-BISH35
I've checked the oil pressure switch and it has only one wire which just reads presure and doesn't seem to involve the fuel pimp. I thought the same thing until I looked at the wiring. It has inly one wire. Is there another switch somewhere else?
Friday, October 16th, 2009 AT 9:44 AM
