2000 Chevy Blazer
BOONES4
  • 2000 CHEVROLET BLAZER
Engine Mechanical problem
2000 Chevy Blazer 6 cyl Four Wheel Drive Automatic
how to put back in time did a intake gasket and put it back without moving anything now it sounds like its under water tring to run how bad is this
Sunday, April 11th, 2010 AT 6:33 PM
BMRFIXIT
  • 19,053 POSTS
Remove the spark plug for number one cylinder.
Rotate the crankshaft until number one cylinder is in the compression stroke.
Align the 2 reference marks on the crankshaft balancer (1) and (4) with the 2 alignment marks (2) and (3) on the front cover.
Install the spark plug.
check rotor inside distributor
remove and reinstal the distributor.
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_708.jpg
Monday, April 12th, 2010 AT 6:22 PM
