Thermostat replacement?
BMRFIXIT
  • 19,053 POSTS
No heat temp gauge reading cold
antifreeze full
1st step is to replace the thermostat
Friday, September 11th, 2020 AT 3:35 PM (Merged)
88K5
  • 1988 CHEVROLET BLAZER
  • V8
  • 4WD
  • 70,000 MILES
I have an 88 K5 Blazer with a 5.7 liter. I replaced all hoses, radiater, water pump, thermostat and housing. Also replaced the heater core. The truck never overheated before but was leaking every where. After I replaced all this it began overheating. When the thermostat is in it only gets hot on the P/S of the radiator. The lower hose, heater core supply and return line, and the thermostat housing all get hot along with the P/S tank on radiator. The upper hose and D/S of tank stay cool. Some one give me some thing before set the dang truck on fire.
SWILLIAMS
  • 597 POSTS
Almost sounds like the wrong water pump. Which belt drive system do you have? If it's a serpentine with the pump driving off the back side the pump is reverse rotation. If it has V belt drive to the pump it is standard rotation. That can be a PIA from 87-89 because they used both drives depending on the options.
The other thing could be the thermostat is in upside down. OR it is a bad one OOB. Seen that happen more than once.
