1999 Chevy Blazer no power to fuel pump
DWEIZEL130
  • 1999 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 150,000 MILES
I have no power to the fuel pump I replaced my relay, and the oil presure switch I have power at the relay and I have power to the gauge side of the connector the fuses are good I have power to the fuelpump side for about 2 seconds after I turn the key off but not when I turn it on I dont have any power at the connector replaced the pump already also I was told the the ignition switch wires could be bad but can prove that because this all started after the truck died and I hit the tank and then I got fuel pressure and then drove it home
Tuesday, December 9th, 2008 AT 2:08 PM
The fuel pump should come On for 2secs before the relay de-energizes-. You menitioned fuse is good and relay has power-you need to check the computer control of the relay/12 volt relay drive
https://www.2carpros.com/forum/automotive_pictures/12900_oil_sending_unit_and_fuel_pump_circuit_89.gif
Tuesday, December 9th, 2008 AT 2:42 PM
