1998 Chevy Blazer Idles smooth no power
135,000 MILES • 6 CYL • 4WD • AUTOMATIC
1RAMSFAN1
  • 12 POSTS
Checked igntion system, new tune-up parts , fuel filter , Timing not adjustable , exhaust system ok. Vehicle takes for ever to accelerate, if you keep your foot into long enough will get going , sometime backfires. Now yes i did a fuel pressure test and got a key on engine off about 55psi running about 50psi does increase some with acceleration. I see my readindgs but feels like lack of fuel. Also engine vacuum is low abuot 12in at idle and droups to 0in on acceleration. I've still been leaning towards fuel pump what do you think ,thanks.
Mar 5, 2009 at 4:25 AM
MERLIN2021
  • 17,250 POSTS
With only 12hg of vacuum, either a mechanical engine problem, or more likly a restricted exhuast system, recheck the converter.
Mar 5, 2009 at 9:58 AM
1RAMSFAN1
  • 12 POSTS
There is a brand new converter on truck , but i un bolted the y pipe at the manifolds and truck ran the same vacuum also the same , only thing haven't done is a compression test , just dosen't seem like problem runs smooth without misfire. any other thoughts!
Mar 5, 2009 at 10:17 AM
1RAMSFAN1
  • 12 POSTS
Oh, Timing is not adjustable , but when i put a timing light on mark it's running at tdc that didn't seem right almost like retared. Seems to me timing should be around 8 to 10 before tdc. Distrubutor is in right , tryed moving it one thooth both ways truck would not run.
Mar 5, 2009 at 10:27 AM
MERLIN2021
  • 17,250 POSTS
Whats the engine size in liters? And at this stage you should be doing a compression test of all cylinders, you may have a worn cam or weak valve springs...
Mar 5, 2009 at 10:36 AM
1RAMSFAN1
  • 12 POSTS
4.3L i will do compression test tomorrow , but to listen to engine idle you wouldn't think compression problem , I mean wore cam or weak valve springs engine would probable mis right?
Mar 5, 2009 at 10:43 AM
MERLIN2021
  • 17,250 POSTS
While your at it test the TPS should be at these specs, operation smooth and no spikes as you move it!
https://images.2carpros.com/forum/automotive_pictures/62217_tp_2.jpg
Worn valve springs may cause idling problems, but a worn cam can run ok at idle but not under load.
Mar 5, 2009 at 10:53 AM
1RAMSFAN1
  • 12 POSTS
Compression test 180 psi all cylinders. I'm taking shot at fuel pump no where else to go!
Mar 7, 2009 at 4:59 AM
MERLIN2021
  • 17,250 POSTS
12 hg of vacuum still says a breathing problem...intake is ok no restricctions? Throttle OK?
Mar 7, 2009 at 8:48 AM
1RAMSFAN1
  • 12 POSTS
I agree about the vacuum this thing has me stumped. I was thinking air flow sensor but no codes. Don't know what else too check.
Mar 8, 2009 at 4:15 AM
MERLIN2021
  • 17,250 POSTS
Just for the hell of it, try removing the EGR, is the pintle OK, closing all the way? Carbon free? And the PCV?
Mar 8, 2009 at 8:26 AM
1RAMSFAN1
  • 12 POSTS
funny you said that because i took off the egr valve a couple of days ago looked ok. I'm changing fuel pump probablely a waste of time of time. whats going on with this car guys. should i pull the intake or what.
Mar 8, 2009 at 5:00 PM
MERLIN2021
  • 17,250 POSTS
Still sounds like a restricted exhaust, you said you replaced the cat? Was the bed inside broken up? May have a chunk lodged in the exhuast of muffler.
I'm still stuck on the 12hg vacuum! Throttle is working OK? Maybe a strange problem with a bypass hole being clogged on throttle plate?
Mar 9, 2009 at 4:03 AM
1RAMSFAN1
  • 12 POSTS
I thought that too so i unbolted the y pipe at the exhaust manifolds and ran vehicle still the same , vacuum reading did not increase. Is there a possablity that the ignition timing is not right?
Mar 9, 2009 at 6:14 AM
MERLIN2021
  • 17,250 POSTS
I doubt the timing is too far off with compression of 180 per cyl. Air filter is clean? Try cleaning the MAF, they make MAF cleaner spray now, worth a shot. MAF's dont hardly ever set a code even when they go bad, try unlpugging it and going for a quick ride, this forces the PCM to use an average input.
Mar 9, 2009 at 9:13 AM
1RAMSFAN1
  • 12 POSTS
ok i'll try that, waiting on fuel pump , i already lower ed fuel tank so i'm going to replace pump. Let you know what happens. This truck is a pain.
Mar 9, 2009 at 9:53 AM
MERLIN2021
  • 17,250 POSTS
Ok let us know what happens.
Mar 11, 2009 at 2:36 AM
1RAMSFAN1
  • 12 POSTS
Ok guys put fuel pump in runs the same. Throttle engine slowly seems ok. Throttle hard stumples and pops threw air box. I unpluged air flow sensor like you suggested runs even worse , really pops back threw air box. Besides exhaust is there anything else that could be causing back pressure or do you think it could still be related to the air flow sensor? Have never not been able to figure out a problem with a vehicle , begining to wonder with this one.
Mar 16, 2009 at 11:08 AM
MERLIN2021
  • 17,250 POSTS
Could be this TSB appies to you...
SPECIAL POLICY ADJUSTMENT-SEQUENTIAL CENTRAL PORT FUEL INJECTION (SCPI) FAILURES IN CALIFORNIA ONLY (YF5 EMISSION EQUIPPED) SERVICE CAMPAIGN BULLETIN Reference Number(s): 99066F, Date of Issue:  04/01/2003 Superceded Bulletin(s): 99066E, Date of Issue:  February, 2003 Related Ref Number(s): 99066A, 99066B, 99066C, 99066D, 99066E, 99066F ARTICLE BEGINNING CONDITION Some owners of 1996, 1997, 1998, 1999, 2000, 2001 and 2002 model year S/T, M/L, C/K, G, P and W4/NPR trucks and 2003 NPR trucks that are registered in California, equipped with 4.3L (RPO L35 and VIN Code W or RPO LF6 and VIN Code X), 5.0L (RPO L30 and VIN Code M) or 5.7L (RPO L31 and VIN Code R) engine, and California emissions (RPO YF5), may experience a Service Engine Soon light, misfire, rough idle or hard start due to a deposit build up on the Sequential Central Port Injector (SCPI) poppet valve(s). The deposit build up may cause injector poppets to stick closed. Fuels used in California have been found to interact with the SCPI system to cause the deposits. SPECIAL POLICY ADJUSTMENT This special policy covers the SCPI failure condition described above for a period of ten (10) years or 200,000 miles, whichever occurs first, from the date the vehicle was originally placed in service, regardless of ownership. The repairs will be made at no charge to the owner. This special policy applies ONLY to repairs requiring SCPI system servicing and/or injector cleaning and/or MFI assembly replacement of the SCPI system. The customer should not be charged for performing a system check when it is determined that the SCPI system is not the cause of a customer complaint (labor operation T5532 is provided to submit claims for such system checks). Any additional necessary diagnosis and repairs CHEVROLET: 1996 - 2002 Certain S/T, M/L, C/K, G, P Trucks Equipped with 4.3L (RPO L35-VIN Code W or RPO LF6-VIN Code X), 5.0L (RPO L30-VIN Code M) or 5.7L (RPO L31-VIN Code R) Engine and California Emission Equipped (RPO YF5) GMC: 1996 - 2002 Certain S/T, M/L, C/K, G, P Trucks Equipped with 4.3L (RPO L35-VIN Code W or RPO LF6-VIN Code X), 5.0L (RPO L30-VIN Code M) or 5.7L (RPO L31-VIN Code R) Engine and California Emission Equipped (RPO YF5) ISUZU: 1996 - 2002 Certain W4/NPR Trucks and 2003 NPR Trucks Equipped with 4.3L (RPO L35-VIN Code W or RPO LF6-VIN Code X), 5.0L (RPO L30-VIN Code M) or 5.7L (RPO L31-VIN Code R) Engine and California Emission Equipped (RPO YF5) SECTION: Special Policy Bulletins NOTE: This bulletin is being revised to add the 2002 and 2003 model years to the SCPI Special Policy on certain S/T, M/L, C/K, G, P and W4/NPR truck models. Please discard Special Policy Bulletin Number 99066E, dated February, 2003. Page 1 of 6 SPECIAL POLICY ADJUSTMENT-SEQUENTIAL CENTRAL PORT FUEL INJECTI...that are not related to the SCPI condition are NOT covered by this special policy. The customer should be informed that any further service that is not covered by new vehicle warranty will not be covered by this policy. VEHICLES INVOLVED Involved are certain 1996, 1997, 1998, 1999, 2000, 2001, 2002 S/T, M/L, C/K, G, P, W4/NPR and 2003 NPR model vehicles registered in California, equipped with 4.3L engine (RPO L35-VIN Code W or RPO LF6-VIN Code X), 5.0L engine (RPO L30-VIN Code M) or 5.7L engine (RPO L31-VIN Code R) and California emissions (RPO YF5). This Special Policy covers all vehicles within these model years, with these engine and emission RPOs. PARTS INFORMATION Parts required to complete this Special Policy are to be obtained from General Motors Service Parts Operations (GMSPO). Please refer to your "involved vehicles listing" prior to ordering parts. Normal orders should be placed on a DRO=Daily Replenishment Order. In an emergency, parts should be ordered CSO=Customer Special Order. PARTS INFORMATION Part Number Description Qty/Vehicle 12345382 Sealant, Thread, Med. Strength (6 ML) As required TBD* Cleaner, Top Engine (24 ml) If required and available TBD* Cleaner, Top Engine (15 oz) 24 ml (12346535 size alternative) 12345104 Cleaner, Port Fuel Injector (20 oz) If required 15050573 Asm -Fuel Tank Fill Pipe (97-99 M/L Van) 1, if required 15747585 Asm-Fuel Tank Fill Pipe (99 C/K E63 w/o AC7) 1, if required 15747588 Asm-Fuel Tank Fill Pipe (99 C/K E62 w/o AC7) 1, if required 12568332 Assy, V6 Fuel Injector 1, if required 88894355 Bracket, V6 1, if required 17113215 Kit, V6 Seal 1, if required 93441235 Assy, V8 Fuel Injector 1, if required 93442096 Bracket, V8 1, if required 17113206 Kit, V8 Seal 1, if required * Top engine cleaner part number 12346535 and 1050002 are no longer California compliant. California dealers will be notified via a DCS message when new alternative cleaner part numbers become available. NOTE: Isuzu Parts Ordering: In order to comply with the 10-digit Isuzu part numbering system, Isuzu dealers must add an "8" to the beginning and a "0" to the end of the listed 8-digit part numbers when ordering parts through AIPDN.
Mar 17, 2009 at 5:52 AM
1RAMSFAN1
  • 12 POSTS
Truck is in Arizona, I read tsb but it really doesn't seem to be what this truck is doing , no misfires. If i could find the source of the low engine vacuum i could solve the problem. Exhaust back pressure was ruled out, do you think something within intake manifold. Should i venture that way? If you heard this truck run you'd swear it has a plugged exhaust. But like i said i unbolted y-pipe it was the same. The low vacuum is the answer, so what about intake?
Mar 17, 2009 at 6:13 AM
MERLIN2021
  • 17,250 POSTS
The only thing I think could rob the vacuum, is a bad leak, or the EGR system....I would pinch off the brake booster and see if manifold vac comes up too...just a thought.
Mar 17, 2009 at 6:42 AM
1RAMSFAN1
  • 12 POSTS
Ok guys think i'm on the right track. I droped the y-piipe on the exhaust again because i keep leaning that way. Started truck and went under, left manifold sounded like good flow , but right side had a muffled sound so i covered it with a rag and engine nearly died. Pulled that manifold looking for blockage looked ok. So i removed valve cover and turned crank by hand watching rocker arms. looks like the #1 exhaust valve is hardly opening. Middle one a little better , last one looks good. Looks like i have a camshaft problem which was mentioned before. My compression is good because valve is closing ok but not opening enough to let out exhaust. Low vacuum and poping back threw intake. What do you think?
Mar 17, 2009 at 12:40 PM
MERLIN2021
  • 17,250 POSTS
I think you should check for bent push rods...A badly worn cam will do it as well, collapsed lifters...try removing the rods and lifter, do a leak down test on the lifters, if you can choke the engine by hand, you are on the right track!
Mar 18, 2009 at 12:31 AM
