I have a vehicle that was in the storm and sat for 6 months. I then replaced the spark plugs and the crank sensor,I replaced a burned fuse in the fuse relay box under the hood and then I poured gas into the throttle body to try and start it. I cranked it up and it ran only long enough to burn the fuel I put into the throttle body and then it stalled. I tried to pat the gas peddle while its running and the engine did not rev up. Can you help?
Mar 11, 2010 at 12:42 PM
