2001 Chevy Blazer connector
136,000 MILES • 6 CYL • 4WD • AUTOMATIC
CHRISSCRUGGS
  • 8 POSTS
i have a connector tha is behind the throttle body it has a bracket on the wires that bolts to the top of the intake the wires are black and yellow can somone tell me where it goes
Feb 9, 2010 at 7:47 AM
HMAC300
  • 48,601 POSTS
it might be the coolant sensor....
Feb 9, 2010 at 10:19 AM
CHRISSCRUGGS
  • 8 POSTS
[quote:440e446482="hmac300"]it might be the coolant sensor....[/quote:440e446482]will it run without it
Feb 9, 2010 at 2:56 PM
HMAC300
  • 48,601 POSTS
i'm not really sure it is the coolant sensor as it could be something like the cam sensor too. But in answer to your question, no it will not run without it. If it's bad it must be giving you a code so you need to pul your codes to find out what is wrong......
Feb 10, 2010 at 2:19 AM
